Air Conditioning problem
2010 Subaru Legacy 4 cyl All Wheel Drive Automatic
Have new 2010 Legacy that fails to cool the car. the A/C is set to max cool, fan fast. After sitting in the sun for a few hours, inside temp 120 degrees, the output from the vent at best is about 60 degrees. After running for 40 minutes it brought the cabin temp down to about 90 degrees. The cabin filter is new, the freon/coolant is correct with no leaks per dealer. We even went to another vehicle on the lot and tested it with same thermometer and it did do a little better but not much. Dealer tells me that they changed the A/C this year to a on demand compressor with a sensor that determines cabin temp unlike old compressors with a clutch. Has anyone else noticed the lack of cooling or have any suggestions?
Jun 22, 2010 at 6:42 PM
