2004 Subaru Legacy Smell Antifreeze
2004 SUBARU LEGACY
87,000 MILES • 4 CYL • AWD • AUTOMATIC
DAVISPEG
Thank you for the response to my initial question, but based on your reply, I think my question was misleading. The antifreeze is evaporating (or leaking) from the reservoir, not from the radiator. And the smoke is coming from under the hood and wheel-well, not from the exhaust. Could this be from a broken hose or damaged belt? Also, the small fan under the hood is not turning when the car is idleing. Any suggestions? Thank you.
Jan 25, 2009 at 7:54 PM
2CARPRO JACK
  • 11,533 POSTS
Have the cooling system pressure tested for leaks, this will show any ones that are too small to notice right away.How hot does it get without the fans coming on?
Jan 26, 2009 at 7:22 AM
DAVISPEG
Thank you for your reply. In response to your question; The gage does not indicate the car is running hot. The gage stays on line between hot and cold.
Jan 26, 2009 at 9:07 AM
2CARPRO JACK
  • 11,533 POSTS
then the fans wont come on.They are designe dto coem on when the engine gets hot
Jan 26, 2009 at 12:25 PM
