2002 Subaru Legacy Enginie Hesitation
2002 SUBARU LEGACY
112,000 MILES • 4 CYL • AWD • MANUAL
MEREDITHHEMENWAY
My engine hesitates after I refuel but only does so briefly--maybe for about 2-3 minutes following refueling. I do tend to run my tank down nearly to empty and then fill completely up, but I have noticed that this does still occurr if I fuel at the half way mark, too.
Is it a clog in my fuel filter or my injector? I had all spark plugs changed 11 months ago and typically have my oil changed every 3,000. I haven't experimented with adding a fuel additive.
Dec 15, 2009 at 11:53 AM
MHPAUTOS
  • 31,937 POSTS
HI there,
Thank you for the donation,
We have to eliminate some basic things first,
Change the filter, check fuel pressure, air filter, run a scan to check for any unresolved fault codes, i would be looking foe a EVAP code as i feel this may be the area of this problem, start there and report any findings.
mark (mhpautos)
Dec 15, 2009 at 5:48 PM
