2001 Subaru Legacy gasoline odor in very cold weather
2001 SUBARU LEGACY
85,000 MILES • 4 CYL • AWD • AUTOMATIC
2001SUBARULEGACYGTWAGON
when the temp drops below 20F, there is a strong smell of gasoline inside the car for the first 15min or so of operation. this only shows up when it's really cold.
also, a 'hot' smell is detected sometimes (possibly antifreeze) after prolonged operation.
concerned that the fuel smell could be dangerous; what could the problem be, and what is the likely repair cost?
Feb 9, 2009 at 8:34 AM
2CARPRO JACK
  • 11,533 POSTS
First off, need to carefully inspect it for any leaks.Look around the injectors, at all connections.Does it put out any excessive amount of black/dark smoke when you can smell fuel? It may be enriching too much for the extreme cold.Cost is impossible to guess without knowing the problem
Feb 10, 2009 at 7:58 AM
Thanks - will check next time it's cold for leaks around the injector.
No dark/black smoke on start up, tho there is a stronger smell of fuel in the exhaust than there used to be when it starts.
The smell is strongest inside the car when it's cold, not sure if it could be something with the fuel line, or the tank?
Thanks.
Feb 10, 2009 at 8:09 AM
2CARPRO JACK
  • 11,533 POSTS
Inspect the fuel system for any leaks, gas wil leave a "stain" where it leaks. No smoke, but rich? may be a coolant sensor causing an over-rich mixture due to temp outside
Feb 27, 2009 at 8:06 AM
