2000 Subaru Legacy DENTONATION KNOCK SENSOR
2000 SUBARU LEGACY
100,000 MILES • 4 CYL • AWD • AUTOMATIC
DWEED
WHERE IS THE DENTONATION KNOCK SENSOR LOCATED?
DOES ANYTHING HAVE TO BE REMOVED TO GET AT IT TO CHANGE IT?
THANKS
Jun 4, 2010 at 8:16 AM
CRZYDRVR
  • 432 POSTS
If you can locate where the throttle cables are attatched to a bracket, that is bolted on to the intake manifold. If you look almost straight down it is mounted to the engine block. It has a 12mm head on the bolt.
Jun 12, 2010 at 3:09 AM
