Have oil leaks around valve cover, belt cover seals. How hard is it to replace seals?
Mar 2, 2009 at 9:16 PM
MHPAUTOS
CERTIFIED EXPERT
Hi there, replacing the rocker cover gaskets is not that hard , just a bit of a fiddly job, take your time and you should have no problems the 2.2 will take about 1.5 hrs and the 2.5L about 2 hrs the gaskets are around $30 .00 the set, prices will vary depending on quality.
