1998 Subaru Legacy P0740 code
1998 SUBARU LEGACY
154,000 MILES • 4 CYL • AWD • AUTOMATIC
PSUE321
Not sure if trans or electrical problem. Car has rebuilt trans w/20,000 miles. Use for paper route so rough driving. Got P0740 code twice in 3 days. Son has repalced TCC solenoid on another car, but not Subaru. Does the valve body have to be removed to replace TCC solenoid? He's worried about bearings inside. Any special handling required? Should we check something else before replacing the solenoid? He would like a diagram but all I can find is full manuals. Basically anything you can tell me would be great. Thanks so much.
Oct 21, 2009 at 4:44 PM
MATHIASO
  • 1,209 POSTS
P0740
Torque Converter Clutch System Malfunction
this code is giving a list of solenoids and sensors to test. the problem is with one of them setting the code above.
Check throttle position sensor circuit
Check torque converter turbine speed sensor circuit
Check engine speed input circuit
Check brake light switch circuit
Check ATF temperature sensor circuit
please write if you have further questions
about components location, testing.
thanks
Oct 21, 2009 at 5:43 PM
