1997 Subaru Legacy oil leaks
1997 SUBARU LEGACY
75,000 MILES • 4 CYL • AWD • AUTOMATIC
LIZBETH61
car is a legacy outback.Had a large oil leak repaired 4 months ago .cam seal water pump crank seal oil pan seal trans pan seal valve cover gasket and oil filter replaced. The car is again leaking oil after 4 months.Where else could the car be leaking oil, it is more than one oil leak.
Nov 28, 2009 at 8:11 PM
KHLOW2008
  • 41,814 POSTS
Hi lizbeth61,
Thank you for the donation.
If the oil leaks stopped after the replacement of the parts concerned and starts to leak again after 4 months, the leaks could be related to those areas.
Without a vusual inspection it would not be possible to identify the source. You would need to get it checked to understand where the leaking is coming from.
Nov 28, 2009 at 10:27 PM
