I remembered the old adage, check the easy things first. I cranked the engine over with the fuel line off, nothing. so i ripped the dash apart to check the pump relay, then i pulled the pump out, took it in the garage to hook it up to a battery charger to test it, nothing. so i rubbed the two leads together and you can guess the rest, pouff the oil pan under the pump caught fire so i ran it outside. Then i knew the pump was bad.
Thanks for the help!!
Mar 1, 2010 at 9:51 PM
