i have a1995 subrau legacy with a 2.2 engine here,s my problem when i let the motor idle for more 20 minites or so the temp gauge goes way up so i check the radiator cap it is not hot fans are working fine when i rev the engine up 2000 rpm the gauge starts to drop to normal range also when i drive up high mountain passes it does not overheat i had the coolant temp sensor replaced themostat replaced also and the water pump changed
Jun 17, 2008 at 1:31 PM
