1994 Subaru Legacy Brakes
1994 SUBARU LEGACY
20,000 MILES • 4 CYL • FWD • MANUAL
RUDE
I removed the front calipers to install new pads, now I have very little brakes, I understand it's not like regular brakes because of the hill holder system, how do I get my brakes working again on a Subaru Loyale
Mar 9, 2008 at 9:59 AM
MERLIN2021
  • 17,250 POSTS
Did you disconnect the hydraulic hoses? If yes you need to bleed them, if not, pump till pedal is firm...
Mar 9, 2008 at 10:06 AM
MERLIN2021
  • 17,250 POSTS
Yes I did open the lines?
Answer to PM:Fill master, open bleeders, and let them drip, it's called gravity bleeding, allow drip until it's a steady stream...DO NOT let master to run dry! Use DOT3 brake fluid omly! Close bleeders, and pump!
Mar 9, 2008 at 10:24 AM
