I have a 92 subaru with a 2.2l. recently when started when cold. the idle will jump up to around 3000rpm then fall to about 500 rpm. it will continue to due this until it reaches a good opperating temp after about 10 minutes. The engine then will idle around 300 to 400 rpm. Just enough to barely run. it has died a couple of times at a stop light, but runs fine once warmed up as long as Im off the idle and have a little gas peddle to keep it up around 1000 rpm at a stop. will operate fine for normal driving around town just a problem when cold or at idle. thanks for any help. Dan
Mar 9, 2008 at 11:42 AM
