[quote:4f3ba1b3c1="izzyaz"]Transmission problem
1991 Subaru Legacy 4 cyl All Wheel Drive Automatic 157333 miles
My front-right CV joint went out on me about a month ago. While it was beginning to go out, the transmission started to slip. When my CV joint broke, the transmission would not let my car go past 37mph. It seems like too much of a coincidence. If I replaced my CV joint, would that fix my transmission issue? Does the CV joint tie in with this problem or is my transmission just bad?[/quote:4f3ba1b3c1]
Have you checked the level of your tranny fluid? If you have been running around on a bad CV Axle it has most likely damaged the seal and has been leaking tranny fluid.
Post findings here in forum....
Jan 7, 2019 at 5:47 PM
(Merged)
