1992 Subaru Legacy Headlights not controlled by switch
1992 SUBARU LEGACY
IDRAGO1
Electrical problem
1992 Subaru Legacy 4 cyl Front Wheel Drive Automatic
I have replaced the headlight switch and the ignition switch.The headlights are still no longer controlled by the switch. When you turn the key on the headlights come on and wont turn off via the switch only when you turn the key off do they turn off. I cant figure out where the problems lies. Please help!
Oct 17, 2010 at 3:29 PM
KHLOW2008
  • 41,814 POSTS
Hi IDrago1,
Thank you for the donation.
Is your vehicle equipped with Daytime Running Lights?
Are you able to switch between high and low beams?
When connector at multifunction switch is disconnected, does the headlights goes out?
Oct 18, 2010 at 7:03 AM
