1991 Subaru Legacy overheats when heater is on
1991 SUBARU LEGACY
155,000 MILES • 4 CYL • FWD • AUTOMATIC
JCUTCH
My car has always run great. a while back I ran the heater full blast for a while for the first time in a long time. It caused my car to overheat. My coolant was very dirty and hadn't been changed in a while. So I flushed my radiator and put new coolant in. After that my car overheated anytime I drove it. So I had a professional mechanic replace the thermostat. It seemed fixed for a while, till I turned the heater on. Now my car heats up to running temperature in less than a mile, and overheats on longer drives (40 minutes or more) and overheats when the heater is turned on. so I have just been avoiding turning the heater on and keeping my drives short, I turned the heater on yesterday for a short time to see what it would do and it blew hot at first then started only blowing cold... my coolant levels are good, i check it often, pretty sure theres no air in the system. seems very strange! any ideas? no one believes me when I tell them that it overheats with the heater on!
Aug 7, 2010 at 1:10 AM
No one believes you because it should do the opposite. However, if you have heat and then lose it, chances are there is air in the system. Have you bled it?
Sep 2, 2010 at 10:36 PM
JCUTCH
yeah I have bled the system, some one else suggested i may have some bad heater hoses.. I will try changing those next.
Sep 2, 2010 at 11:28 PM
The only concern with any hose is if it collapses. With the heater on, loosten the return heater hose and see if any air comes out.
Sep 3, 2010 at 9:44 AM
