1991 Subaru Legacy Jump Time
1991 SUBARU LEGACY
125,000 MILES • 4 CYL • AWD • AUTOMATIC
POOGIE
The tension gear on the timing belt sheared off- it jumped
time- we replaced gear and belt and think we have lined up correctly- still won't start...
what can we do-
Jun 12, 2008 at 11:52 AM
LEGITIMATE007
  • 5,121 POSTS
you will have to check compression because , usually when a belt jumps timing, there is damage to the valves. checking compression will help determine if there is any loss of compression at the individual cylinders; leading to the conclusion that those valves at the weak cylinder is damaged.
Jun 12, 2008 at 3:02 PM
