1990 Subaru Legacy dead cylinder
1990 SUBARU LEGACY
MISÞLACEЙ
Engine Mechanical problem
1990 Subaru Legacy 4 cyl All Wheel Drive Manual
the number 1 cylinder does not hit got gas compression and fire no smoke from the tale pipe or anywhere for that matter the pug comes out a little wet but not to bad, but still wet. not sure that a vac leek would make just one cylinder do this but not sure and thought maybe could be crank sensor but would think the same as vac leak please help cause i cant think of anything else
Jun 12, 2010 at 8:38 PM
MHPAUTOS
  • 31,937 POSTS
Fit new spark plugs and check the leads, also run a scan to check for any unresolved fault codes, most mechanics can do this simple test, start here.
mark (mhpautos)
Jun 13, 2010 at 2:12 AM
