2007 Subaru Impreza centre steering wheel
2007 SUBARU IMPREZA
DEAN BRADSHAW
Steering problem
2007 Subaru Impreza 4 cyl All Wheel Drive Manual
i would like to know how to centre my steering wheel buy removing the steering wheel as not to deploy the air bag but also is the shaft like finger spleenes or quater movements .
Feb 20, 2010 at 3:03 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
this should be done by a wheel alignment, removing the air bag is extremely dangerous and should only be work on by a qualified tech.
mark (mhpautos)
Feb 20, 2010 at 3:21 AM
DEAN BRADSHAW
can i adjust the steering to make it centre by the tie rod ends if so do you adjust both in the same direction and same distance or do you adjust one more than the other and in oposit directions thanks
Feb 20, 2010 at 4:55 AM
MHPAUTOS
  • 31,937 POSTS
This is the toe in adjustment, the steering wheel is held in the straight ahead position and the toe in is adjusted to get thehcorrect mesurements as per alignment specs, you will not get the sewttings correct by eye, close enough is not good enough in this case, even 1-2 mm out will cause p[remeture tyre wear.
Mark (mhpautos)
Feb 20, 2010 at 6:08 AM
