2002 Subaru Impreza High RPM
2002 SUBARU IMPREZA
170,000 MILES • 4 CYL • 4WD • AUTOMATIC
RAMIREZJULIO
Hi, i have 2002 Subaru Impreza Outback that runs at 1800rpm after i replace the battery. I had the same problem last year when i reset a check engine code, but it whent back to normal after a few miles. Now i have run already 80 miles and is still accelerated. Will you please give me a clue to start?
Mar 10, 2009 at 6:58 PM
The computer has to relearn itself due to disconnecting the battery 40 cycle/starts to regain its memory Test the idle air control solenoid and throttle position sensor
https://www.2carpros.com/forum/automotive_pictures/12900_subaru_1.jpg
Mar 11, 2009 at 7:19 AM
RAMIREZJULIO
When you say 40 cycle/starts it means turn on and off the engine 40 times?
How do i test these sensors?
Thanks
Mar 11, 2009 at 7:20 PM
It takes about 40 restarts of the engine for the computer to relearn its memory-if it continues check the idle air control valve and the throttle position sensor-
Mar 11, 2009 at 7:40 PM
