2002 Subaru Impreza
2002 SUBARU IMPREZA
145,000 MILES • 4 CYL • AWD • MANUAL
CASH
Hey, I've lost all my gears 2 days ago, im trying to figure out what the problem might be, when I put my foot on the clutch it gets stuck to the floor, I've checked the cable it seems alright,theres no leakage from slave or master cylinders, my folk looks twisted, when the clutch is down the folk doesn't look like its releasing the bearing.
Im guessing i have either a faulty folk or need a new release bearing but Im only guessing.
I would appreciate any ideas on what my problem might be or what the problem is.
If you know what the problem is, could you tell me what parts Iwould need to fix it. Thanx
Jun 10, 2008 at 10:52 PM
KHLOW2008
  • 41,814 POSTS
Hi cash,
If you can shift into gears with engine started, the clutch has failed.
Most probably the bearing is stuck on the pressure plate resulting in it being unable to move backwards to engage the clutch.
You need to remove the trans.
If it is the clutch fork, you would not be able to shift into gear and when you engage gear and try to start, it will pull.
Jun 29, 2008 at 3:08 AM
