Hi, I’m hoping you can help, I cannot find anything on the net or through Subaru forums similar to the problem I am having.
I have a 2000 Subaru Impreza RS 2.5 Manual Trans.
My Speedometer and Tach do not work. The gas Gauge , Temp Gauge even the Clock works, but the Tach and Speedo have given up. Also the Digital display showing my Odometer just blinks with lines across it, and if I click over to the Trip meter , it rolls over and over as if I am travelling 100 km’s a second! Cruise control works, but it’s not like I know how fast I am travelling to set it!!!
Could it be the Vehicle Speed Sensor ? I thought maybe the Gauge Cluster itself, but most I have asked said the all the gauges usually go. I have also pulled out the ECM under the passenger floor and it doesn’t appear to have any moisture and all else seems fine.
The only thing I get is out of those 2 Gauges is that the Tach will (once a week approx.) shoot up to 3 or 4000 RMP for a quick second, then back down to zero.
Any help you would be able to provide would be very much appreciated
Thank you in advance
Rob
Rob
Sep 10, 2008 at 12:47 PM
