P0130 ban 1 sensor 1 o2 sensor too low voltage code set
p0103 maf sensor high input higher airflow then expected
p0170 rich fuel mixture
p0302 cyl 2 missfire
P0325 knock sensor malfunction
first off you got quite a bit of problems i dont know if they all match up tho!.
Po130 usually means that the sensor voltage is too low and the vehicle is running rich. p0130 means that the sensor is high in voltage which means its detecting a high airflow which should cause it to lean up.
P0170 usually will go on with the o2 sensor because its trying to lean it down. in your case it cant make it any leaner but it wants to go leaner. 302 is cyl 2 missfire which is odd because its on the opposite side of the o2 sensor thats reading rich.
p0325 is knock sensor and that could be being caused by the sensor being bad and cylinder 2 acting up.
can you get me a brief history of repairs and such on the vehicle like how its running?
Dec 4, 2009 at 3:20 PM
