2003 Subaru Forester No power to rear wheels, low whirring
2003 SUBARU FORESTER
SPLATTGRAPHICS
  • 10 POSTS
Drive Train Axles Bearings problem
2003 Subaru Forester 4 cyl All Wheel Drive Automatic
Noticing a low whirring noise from the rear, our mechanic ran it on the lift, and noticed the rear wheels not turning with the fronts, they just freewheel. The tranny got hot. He flushed it and changed the fluid and filter, gave my wife a bill for a buck sixty-six, and said he was unsure of why it might be that way. I'm looking for what the likely failure may be and the most sensible way to remedy it. The car is otherwise in excellent shape and has about 100,00 miles.
Aug 25, 2010 at 9:32 AM
MADMIKE1735
  • 951 POSTS
thats an all wheel drive... your front cv axles drive the front tires directly from the transmission, and the rear driveshaft is also powered from your transmission.... if its on the lift, does the rear driveshaft turn while the rear wheels free wheel??? if so, then most likely a stripped ring, or pinion.... if the drive shaft isnt spinning, then it will need to go to a transmission shop....
Aug 28, 2010 at 10:53 PM
