Suspension problem
2003 Subaru Forester All Wheel Drive Manual 2.5X miles
How do I get the 32mm nuts off to remove my rotor assembly? I want to remove the front left shaft driving the wheel in order to fix the inner CV joint. I see each nut has a small depression which is locked into a key hole on the shaft, this is obviously a safety against loosing a nut / wheel. Is is a job for an impact wrench, and a a new nut when you reassemble? I've already broken a long handled socket wrench that I leveraged with a pipe, no way I'm budging it.
Jul 17, 2008 at 12:20 AM
