Hi jonabowman,
Thank you for the donation.
If the brakes remains stuck only after driving, does releasing the bleeder nut releases the brake? If yes, pressure is not returening and if equipped with ABS, the modulator could be the cause.
You mentioned the brake hose was replaced, was it the flexible hose between the caliper and body lines?
Was the caliper replaced complete with the caliper mounts and is it new or used?
Aug 5, 2010 at 3:40 PM
