Parts and Service Done:
New lower and upper intake gaskets, new distributor, new distributor cap and rotor, new spark plugs and wires, new alternator, new fuel spider, new camshaft position sensor, new battery, new catalytic convertors. Fuel pressure within spec.
Problem: Engine had a code P0420 before I replaced catalytic converters. There is no check engine light on. Checked codes and no codes stored. The engine stumbles and will occasionally backfire when I jump on the accelerator. I have checked for vacuum leaks using propane and nothing showed itself. I'm dumbfounded. Any ideas?
Mar 30, 2021 at 9:38 AM
