stumbles under load
1994 MITSUBISHI MONTERO
242,000 MILES • 3.5L • V6 • 4WD • AUTOMATIC
ADAM SAWYER
I just bought a high millage vehicle listed above it is the SR model. The engine ran good but had bad ticking at idle that would go away with throttle. I decided to change timing belt, water pump, oil pump, hydraulic lifters, plugs, cables, crank and cam sensors. Now after reassembled, the engine still has the same excessive ticking but now stumbles when I put it in gear and has no power and backfires. In park, it idles a little rough and smooths out when you give it gas and is hardly drivable. When replacing everything, I broke the EGR from the exhaust to intake manifold, so I deleted it for lack of replacement part availability.
when I installed the lifters, I tried to follow your directions by bleeding them before installing. They came full of oil, so I took a pin and pumped a few times to make them squeezable. Is there a chance that they are not priming and pressurizing therefore not allowing the valves full open/closing range? Or do I possibly need the EGR to work?
This engine by the way is a pain. You have to remove the intake manifold just to get to the injectors and spark plugs, so a lot of diagnostic methods are a pain. Also, no codes when jumping obd1 port.
May 22, 2017 at 5:57 PM
the first thing that comes to mind is the belt might be off a tooth. Here is a guide to help you see if that could be the case.
https://www.2carpros.com/diagrams/mitsubishi/montero/1994
Next is a vacuum leak which you can find by following this guide.
Also check the make sure the air intake boot is in tact.
https://www.2carpros.com/articles/replace-an-air-intake-boot
Please let us know what you find, I am curious ;)
May 26, 2017 at 2:42 PM
ADAM SAWYER
Thanks for your reply. The first thing that I checked was that the timing belt was correct. The timing mark on the crank and all four cam gears are spot on. Vacuum was 15-16 in hg and steady. This seems to indicate late ignition timing, but I don't have a distributor so I'm not sure how to adjust.
May 26, 2017 at 3:29 PM
I am wondering if the MAP or MAF sensor is causing the problem. Check to make sure the sensor is hooked up and clean.
May 27, 2017 at 11:51 AM
