Chances are it is one of the things you mentioned. Here are all the directions for cables and the system. I attached all pictures related to the different procedures. For some reason, the directions are all lumped together for this vehicle.
HEATER CONTROL ASSEMBLY AND A/C SWITCH
REMOVAL SERVICE POINTS
HEATER CONTROL ASSEMBLY REMOVAL
After disconnecting the heater/cooler unit side connections of the air mix damper lever cable and air outlet changeover link cable, remove the heater control assembly.
AIR MIX DAMPER LEVER CABLE, AIR OUTLET CHANGEOVER DAMPER LINK CABLE REMOVAL
Insert a flat-tipped screwdriver into the control base clip from inner side, and then remove the cable by lifting the claw part of the clip.
INSTALLATION SERVICE POINT
HEATER CONTROL ASSEMBLY INSTALLATION
1. Follow the steps below to install the air outlet changeover damper link cable.
1. Set the air outlet changeover control knob on the heater control assembly to the defroster position.
2. Set the air outlet changeover damper link of the heater/cooler unit to the defroster position as shown in the illustration, and then connect the cable to the link pin.
3. Push the outer cable in the direction so that there is no looseness, and then secure it with the clip.
2. Follow the steps below to install the air mix damper lever cable.
1. Set the temperature control knob on the heater control assembly to the maximum hot position.
2. Set the air mix damper lever of the heater/cooler unit to the maximum hot position as shown in the illustration, and then connect the cable to the lever pin.
3. After installation, ensure that each damper operates smoothly by operating the heater control assembly knob.
Dec 25, 2018 at 7:28 PM
