Stuck left caliper appeared luckily in driveway!
Cal-piston seal pushed partially out. Replaced rear calipers as pair. Replaced short left rear rubber line section. Bled brakes. Test=sticking!
Purchased Foxwell OBDII.
Scanner tested all ABS module valves/solenoids tested okay. Performed ABS auto bleed. did not bleed.
Brakes tested=still sticking! Looking like ABS module is bad?
FMRB!
FMRB!
Jun 8, 2021 at 11:01 AM
