Good morning, I had a quick question about an issue on my truck. It currently seems to be stuck in 4H, and when I turn the knob back to 2H the 2H light flashes on the dash. However, I can tell it is still in 4H because I can feel some binding/rear wheel slip in a turn (just while test driving to see if it had gone back into 2H). I can hear the vacuum actuator running for a short while during the "shift" process but it obviously is unable to complete the shift to 2WD. I have checked fuses for the system, as well as tried to drive it forward and then for a bit in reverse to try and see if I could get the transfer case into a neutral loading so it could switch into 2WD. I normally try to do most of my car work myself, so I just wondered if there might be something else I'm missing and should check as I was hoping to avoid a tow, even if I do have to take into to a dealer once I get it back into 2WD. Thanks so much for any advice you might have!
Nov 1, 2019 at 5:48 AM
