Good evening,
Struts do not hold the truck up, they just stabilize the suspension. In your case, you have torsion bars. You can adjust them to raise the truck. I attached a picture for you of the adjustment. You have one on each side.
After you get your height, you will need to get it aligned as the geometry will be off and has to adjust for proper steering.
May 1, 2019 at 5:47 PM
