erratic shifting at low gears, low speeds?
2017 VOLVO XC60
124,000 MILES • 2.0L • 4 CYL • TURBO • 4WD • AUTOMATIC
BHAMDOC1
  • 101 POSTS
I changed the fluid twice on this vehicle to see if the shudder or what feels like shudder goes away. iT DID NOT. I CHANGED THE FRONT DIFF FLUID, SAME THING, maybe a bit better shifting like you would expect from changing fluids.It almost feels as if there is bad gas, or bad plugs, but there are no codes. I cannot get to watch the misfires on the auto for some reason, volvo is always a headache to get any info but ill dig deeper. I am trying to figure out if there is anything else like a transfer case maybe since this is a 4wd that has worn fluid.I also hear a minor PCV whistle which is common on these, I will replace it later, but I doubt has anything to do with it. I did the adaptation reset now. I also did something called recondition oil due to hard or jerky shifting. They recommend it after changing fluids. It des not jerk hard or slip, just the common erratic shifting at low gears, low speeds, once you go above 45 or 50 its all good.I also floored it to see and its super strong, no issues there. Not sure where to look. Can you see if there is a TSB for any software updates on these? it's the T6 AWD
Feb 9, 2026 at 4:18 PM
I have seen the rear differential fluid cause this issue, it wears out and causes the clutches to stick together causing the shudder. I don't see a drain port so you may need to suck the fluid out.
SAE 75W-90 Full Synthetic Gear Oil
Check out the images (below). Let us know how it goes
Feb 10, 2026 at 9:12 AM
BHAMDOC1
  • 101 POSTS
Ya this one is easy to change. Same way as the front i had to suck it out which is not a bog deal. I will try it and see
Feb 10, 2026 at 9:15 AM
BHAMDOC1
  • 101 POSTS
Changed it with same results. Am gonna run some fuel cleaner in it for a bit and see
Feb 10, 2026 at 11:27 AM
BHAMDOC1
  • 101 POSTS
Just looked at the picts from when i bought it from the auction. I see one for when they scanned it it had a p0301 even though am not feeling any misfire. Am gonna check on the plug and coil and see if another scanner has the option to allow me to see any live data as far as misfires
Feb 10, 2026 at 12:23 PM
BHAMDOC1
  • 101 POSTS
Checked one of the plugs i think it looks fine. Never heard of this brand coil not sure if oem ir has been changed before, but the too of them all looks new but maybe cause the cover is on top of them
Feb 10, 2026 at 2:00 PM
BHAMDOC1
  • 101 POSTS
You kind of have to cheaot the scanner to get into afanning some of these. I was in somewhere to check codes and it gave me this,even though if u scan it with a regular obd probably wont show a thing and check engine light is not on. I found these. Even though the picture at auction was for p0301. There is a fluctuation in rpm when say you in a drive through, similar to a vac leak, otherwise stable, but i think it gets it from either a plug, ignition or dirty injectors. I put in some ethanol fleaner and driving it to see
Feb 10, 2026 at 2:55 PM
Yep, I have not heard of the coil as well, I would replace it with an main brand part and change the spark plug just in case, clear the codes and try driving it again. With the first code P0607 idle high tan normal can mean a vacuum leak, this video can show you how to find it.
https://www.youtube.com/watch?v=LRKWV4Are5c
or
https://www.youtube.com/watch?v=xN5pcM-5bso
Please go over these guides and get back to us.
Feb 11, 2026 at 9:08 AM
BHAMDOC1
  • 101 POSTS
I added insta shudder repair rube and then fuel cleaner and its much better
Feb 11, 2026 at 11:25 AM
Thanks for letting us know, we are here to help. Ken
Feb 12, 2026 at 8:21 AM
