Sometimes when I turn the key to the run position with engine off the battery light comes on, airbag light comes on, anti-theft light blinks. Also, I do not hear the fuel pump prime and the coolant temperature gauge stays in cold position even if the engine is hot. Sometimes when those symptoms occur I start the car let it run for few minutes turn it off turn the key to run position engine off all symptoms are gone and i can hear the fuel pump prime. When the symptoms occur and when I start the car put it in gear it goes to limp mode. Usually there are two codes p0882 and p0218. I checked the temperature of the transmission is not overheating.
Sep 20, 2018 at 8:49 AM
