My car listed above as a 1MZ-FE engine. My problem is a recurrent set of noises in the interior, behind the central instrument panel, near and above the transmission cover. The sounds occur when the ignition key is set to "on" (not ACC) before starting the engine and while running. The frequency of the sounds doesn’t change with engine RPM or when the transmission is in gear or in neutral. I would describe the sounds as a series of tap, tap, tap, click and pause and then repeat. Before dismantle everything to gain access to discover source, I would like to know what it’s in there first. My Haynes pepair manual is not useful.Any ideas?
Apr 11, 2019 at 2:02 PM
