strange noise and loss of power...
2005 CADILLAC CTS
216,000 MILES • V6 • RWD • AUTOMATIC
RICKYSH11
  • 75 POSTS
I have a 2005 cadillac cts sport/luxury. When I do a cold start the engine seems to lose power after turning over. There is a strange noise that can be heard before as the car is idling and as long as the ac is on while driving. This noise sounds like rubber rubbing something, it seems to go away after the ac is turned off. Usually when the accelerator is pressed after startup the pedal pulsates or vibrates for a few seconds then goes away after driving for a few seconds. I've also noticed that at times I can see a bit of smoke or dust coming from the hood when at a stop light but haven't been able to observe it under the hood when it happens there is also a burning smell that comes only briefly after I've driven for a couple of miles.... I'm not sure what the problem is but I was told that I needed to replace the serpentine belt. What else can be possible causes of these problems? All fluids are at fill levels and the tires are good and showing now signs of serious wear....
Jul 28, 2014 at 12:41 PM
HMAC300
  • 48,601 POSTS
it may be your belt and tensioner. recommended replacement or both is 60k. the belt can get oil on it and then wear bad like yours sounds like it. it 'may be moving on one of the pulleys and burning the belt off. So replace those first belt and tensioner as the tensioner has lost tension as well.
Jul 28, 2014 at 3:51 PM
