This is the backside of the fuse/relay center beneath the hood. The bulky gray plastic two wire connector at the bottom that has the two orange wires connecting fifty amp Maxi-fuses to the top and middle row sets of twenty amp fuses, does that belong there or is it doubling up on twelve volt current? Should it be removed? I have never seen or heard of its presence in any troubleshooting or schematics. I had to flip the box to snap the picture so the layout is inverted. When I connect the battery the guage cluster and interioir lights are on, full time, key on off position. But when I pull the horn fuse and only the horn fuse the parasitic drain drops from seven amps to .7amps. Your help is greatly appreciated!
Cheers,
Steve
Cheers,
Steve
Nov 29, 2016 at 7:23 PM
