Stops when hot or after driving a little while
2008 NISSAN SERENA
95,000 MILES • 2.0L • FWD • AUTOMATIC
SHELMOY
  • 6 POSTS
After driving over hill or traveling over twenty miles the vehicle slows down until it comes to a complete stop. When stop and parked it takes no rev until after about ten minutes it is ready again. This happens over and over. It has in a new CVT transmission and it is still having same the problem. No check light.
Dec 7, 2016 at 1:53 AM
JOHNNYT73
  • 924 POSTS
You need to report back to the shop that installed the transmission and have them correct the issue.
Dec 7, 2016 at 5:52 AM
SHELMOY
  • 6 POSTS
Thanks alot. There is also an issue where the gear shifter is moving up and down by itself. Both in idle and when driving.
Dec 7, 2016 at 6:40 AM
SHELMOY
  • 6 POSTS
And i must point out that the stopping issue has been happening for the past two years. So even with the old transmission it was happening.
Dec 7, 2016 at 6:51 AM
CARADIODOC
  • 34,306 POSTS
What you're describing is a common symptom of a plugged or collapsing pickup screen inside the fuel tank. They will stretch out and allow fuel to pass after sitting for five to ten minutes. To verify this, attach a fuel pressure gauge. I've been through this three times with two cars. Normal fuel pressure varies between 45 to 55 pounds on my '88 Grand Caravan. When this problem occurs, it will gradually drop to 20 pounds. The first symptom shows up, surging, then stalling, when the pressure drops to 15 pounds. Some engines will not run properly when fuel pressure drops as little as five pounds below specs.
I run the test gauge's hose under the rear edge of the hood, then I clip the gauge under the right wiper arm, or I tie it to the radio antenna, so I can watch it while driving.
Dec 7, 2016 at 5:29 PM
SHELMOY
  • 6 POSTS
Awesome,,,.thanks a million. Will get on it asap..
Dec 7, 2016 at 5:33 PM
Good call CARADIODOC
Please let us know happens so it will help others.
Best, Ken
Nice to see JOHNNYT73 back in here!
Dec 12, 2016 at 10:53 AM
SHELMOY
  • 6 POSTS
Sure. Ok. When we checked the gas tank. The only thing we saw was the pump. Could the screen be inside the pump?
Dec 22, 2016 at 3:30 AM
SHELMOY
  • 6 POSTS
They wanted to be sure before pulling the apart
Dec 22, 2016 at 3:31 AM
The screen can be on the inside or outside of the pump, it might have fallen off and is still in the tank, use a flashlight and look around.
Please let us know what you find so it will help others.
Best, Ken
Dec 22, 2016 at 11:58 AM
