After stopping at a signal light, vehicle sort of staggered like it was running out of gas then stopped pulling at all?
2005 CHEVROLET TAHOE
205,900 MILES • 5.3L • V8 • 2WD • AUTOMATIC
MFITZ825
The vehicle was fine, no slipping, no hard shifts or any indication of a problem. Pulled up to a stop light and started forward on green and vehicle sort of staggered like it was running out of gas then stopped pulling at all. After it sits for a few minutes, it will start pulling for a short distance then staggers and stops pulling again.
Fluid level checked and was a little over the full mark. When completely cold it does not show any fluid at all.
I came across a similar problem somewhere and the fix was changing the fluid and filter (it was clogged). Do you think this is a viable solution?
Sep 10, 2023 at 4:16 PM
Yes, it does sound like this could be the problem, I would try to service the transmission and I would run the codes to see if anything is stored. Here are two guides to help and I have included instructions in the images below for your car:
and
Fill the transmission to the proper level with DEXRON III transmission fluid.
Check the Cold fluid level reading for initial fill only. Inspect the oil pan gasket for leaks.
Check out the images (below). Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
Sep 11, 2023 at 5:08 PM
MFITZ825
I just finished servicing the transmission and after a test drive all seems to be well again. Thank you for your help.
Sep 24, 2023 at 3:58 PM
You are welcome, please use 2CarPros anytime we are here to help.
Sep 25, 2023 at 8:58 AM
MFITZ825
I guess I spoke too soon. Transmission gave out on me last night. Making bad grinding noises, won't go in to reverse and seems to have no 1st gear. Looks like it's replace it or find another vehicle. Thanks for your help anyway.
Sep 26, 2023 at 10:36 AM
Yep, noises are a bad sign, it sounds like you need a rebuilt unit. Here is how to R&R the unit in the images below. This video shows the job being done on a similar car, but the procedure is the same.
https://youtu.be/3vJAojsrfuU?si=aZW6hR6dQO6xjMO6
Check out the images (below). Please let us know how it goes.
Sep 26, 2023 at 11:35 AM
