This could be a pretty serious issue so we need to start with the basics. First let's check for codes and see what is there. Here is a guide that will help with that:
Then we need to spin the engine over by hand with a wrench on the crank pulley because I suspect the engine locked up.
If this is the case, we need to do an oil change and then pour the old oil through a coffee filter.
This will capture all the metal so we can see if this is correct.
https://www.2carpros.com/articles/how-to-change-engine-oil-and-filter
However, if this is not correct then we will need to run through this guide to see what we need to do next:
https://www.2carpros.com/articles/engine-stalls
Lastly, if there are codes and the engine is not locked up then let us know and we can figure out the next steps if we need to change course.
Thanks
Dec 29, 2020 at 2:52 PM
