First of all, I just noticed in your title you said fuse # 12 under the hood. I posted the location for the fuse box under the dash. Here's the correct location for the benefit of others researching this topic. If these are too small to read, I like to copy and paste them into a typing program like MS Word where I can make them bigger.
My light bulb trick has big drawbacks for very intermittent shorts in circuits like this, but now that the short is permanent, it works perfectly for locating the short without wasting a lot of fuses. Basically, all you're doing is replacing the blown fuse with a small light bulb. A common 3157 brake light bulb works well. At most, it will allow only one amp of current to flow, so nothing in the circuits will be overloaded or damaged.
The fourth drawing shows a typical fuse box. In the fifth drawing, the blown fuse has been removed. You'll need a way to connect small jumper wires to the terminals in the box. When you have a large cartridge-type fuse, the box may have two male terminals sticking up. Connect the clip leads right to those terminals. If you have the more common spade-type fuse, you'll need a pair of universal crimp-type terminals. They normally come in a box of a dozen or more. Rather than buying way more than you'll ever need, consider asking a friendly mechanic if he has a couple extra in his toolbox. We all normally do.
Those universal terminals are shown at the top right of the sixth drawing. The two red ones are as they come with those insulators pressed onto them. Those can make it difficult to connect jumper wires to, so the blue one is shown after twisting and pulling to remove that insulator. You may need a pair of pliers to tug them off. Two clip leads are shown at the upper left. Harbor Freight Tools is the best place to find them. They're roughly 15" long and come in a bag of ten for less than $4.00.
In my sad seventh drawing, the two terminals are poked into the terminals in the fuse box. In the eight drawing, the clip leads are connected to those terminals. Next, in the ninth drawing, the clip leads are connected to the light bulb. Now, when the short is present and the circuit is turned on, the bulb will light up full brightness and it will get hot, so be careful that it isn't laying on or against anything that can melt or burn.
A 3157 bulb has two filaments inside. The bigger one will allow one amp of current to flow. The smaller one will allow about 3/4 amp to flow. Depending on how the clip leads are connected to the bulb, maximum current will be 3/4 amp, one amp, or 1 3/4 amp. Regardless, current flow will be much lower than those circuits normally see. This same test can be done with different light bulbs, as needed. The little 194 "peanut" bulb, commonly used for side marker and license lamps, allows half an amp. If you're working in a high-current circuit, typical of fan and window motors, a plug-in 9004 headlight bulb works better. It allows five amps to flow when using the low-beam filament, or six amps with the high-beam. Any of these bulbs will work fine. The point of using different bulbs has to do with very subtle changes in brightness when the short is removed. Using the right bulb just makes that change easier to notice. Additionally, when the short is removed, the circuit is going to resume trying to work. At that point the bulb can limit current too much. In a power window motor circuit, for example, if a 9004 headlamp bulb is used, the motor will run, although slowly, when the short is gone.
That was a lot of extra detail that you won't be tested on later. At this point, if you find the test bulb is bright, the short is present and the circuit is turned on. If the bulb is off or very dim, there is no short in the circuit right now. Now you do things to see what makes the short occur. When you do, the bulb will become full brightness. Press on the brake pedal. If the wiring to the brake light bulbs is shorted, the test bulb will become bright, but nothing will be overloaded or damaged. I like to place a stick between the driver's seat and the brake pedal to hold the pedal down, then run around the vehicle to see if you can do anything to make the short go away. When you do, the bulb will become dim. It will not go out completely because current has resumed flowing through the brake light bulbs. If you look closely, you may be able to see them glowing a little. Look for a chewed-up trailer wiring harness that got pinched under a trunk lid or lift gate, or was wrapped around the hitch and rubbed on the ground a few times. Back in the '90s, a real common cause of shorted brake lights was a trailer connector from U-Haul. They had three red LEDs on them, and something inside the connector commonly shorted.
I haven't looked at your turn signal circuit yet, but up until recently, the brake lights fed through the turn signal switch. If the short is present with the brake light switch on, see what happens when you turn the signal switch one way, then the other.
If the test bulb hasn't indicated a short yet up to this point, try using the horn. This test might get a little confusing. I suspect this is not the circuit with the short because there is only one wire running up the steering column that can be shorted. The horn relay and the horns, and a short, won't be powered up until the horn button is pressed. Before you turn on the ignition switch, try blowing the horn. The test bulb is likely to get almost full brightness because horns do draw a lot of current, but since the test bulb is limiting that current, expect the horns to sound rather sickly. The point is if they do try to sound, that circuit is not shorted. That furthers my suspicion the short is in the brake light circuit.
Remember, there is a transmission shifter interlock tied to the brake lights, so that's another item to consider. I haven't run into one of those solenoids shorted yet, but some other things I have solved with this test light setup include a mudflap screw run through a wire harness, a rear seat mounting bracket set on top of a wiring harness and crushing it, and an aftermarket trailer harness left-turn wire pinched under the lamp housing. I found the mudflap screw by going around the vehicle while banging on it with a rubber hammer. The shorted trailer harness wire showed up when I began to remove the left tail light housing. When I loosened the screws, the test bulb became dim and the brake lights started to glow just bright enough to see if you looked really close. The wire had folded under the screw, then the insulation rubbed through over time against the screw threads.
Another really common place to find shorts is right under the driver's foot area on GM vehicles. A huge clue is to find a large hole worn through the carpeting. Another common place to find shorted wires on almost any brand of vehicle is in the wiring harness between the door hinges. A dandy clue is the test bulb's brightness will flicker when opening and closing the door. That harness won't affect brake lights, but if you run into that, I have a suggested fix.
Once again, there's a lot to consider. I added a lot of extra detail for your viewing pleasure. Once you have the test bulb connected, see what it does and what you can do to make it get bright, dim, or go out, and let me know.
Mar 29, 2024 at 4:21 PM
