Still scrubbing when I turn right even after the rebuild,
1992 TOYOTA PASEO
150,000 MILES • 1.5L • 4 CYL • 4WD • AUTOMATIC
REICHER82
Okay, I have a 1992 Toyota paseo just got done replacing the front driver side hub assembly including brand new rotor, brake pads, wheel bearing , a new hub, a new caliper and also new CV joint it seem to be running very well but when I make a right turn you can hear a faint grinding, what could I have missed all help is definitely appreciated
Feb 29, 2016 at 7:29 PM
REICHER82
Seems to be running very smoothly and only after about 10 miles did it fail and start scrubbing when I turn right just thought I'd add that, Thanks
Feb 29, 2016 at 7:41 PM
MHPAUTOS
  • 31,937 POSTS
Fitting wheel bearings to these front wheel drive cars can be tricky, if you pushed on the inner race and not the outer race to install you may have damaged the bearing, how did you press it in?
Mar 1, 2016 at 3:29 AM
REICHER82
I did it with a 24 ton machine press
Mar 1, 2016 at 5:20 AM
If I can but in here, have you checked the rotor dust shield it could be touching the rotor when you turn, please check it and get back to us
Mar 3, 2016 at 9:28 AM
