My water pump blew out. So I picked up a new water pump and installed it. No problems with the installation. We filled it up and let it idle to operating temperature to make sure it ran right.
It made it to operating temperature and kept climbing until it was almost into the red and then went back down. We figured a air pocket but it has a vented reservoir so it should burp itself. It starts climbing again and this time it goes to the line before the red and goes back down.
We decided to get a new thermostat and gasket. We replaced those with the fail safe and higher end gasket. After that we noticed a leak near there but saw that it was coming from the upper radiator hose. So We replaced that as well.
We filled up the hose and finished installing it. There was no more leaks on the ground or on the engine.
Here is where it gets confusing. We decided to drive it a little to maybe help it burp. As I'm hitting the gas the temperature goes up slowly until the light comes on and it is overheating. I stop to the side of the road and it immediately goes back down. I even changed out the fan clutch. I am at a loss at why it is still overheating like it is.
Aug 25, 2019 at 2:42 AM
