New master, rebuilt vacuum 2018, rebuilt wheel cylinders 2010. Brake pedal is stiff with zero travel.
Nov 5, 2018 at 1:37 PM
CERTIFIED EXPERT
Good afternoon.
Do you have vacuum to the booster? Remove the hose and verify there is vacuum.
If you have a vacuum gauge, check the amount of vacuum to the booster.
Does the linkage move freely? Look under the dash and be sure the pedal and rods move freely.
Nov 5, 2018 at 1:49 PM
CONAGHER
MEMBER
Pedal travels freely while l bench bleed master, will not travel with brake line attached. I will check for vacuum.
Nov 5, 2018 at 1:57 PM
CERTIFIED EXPERT
Sounds like a plan. Keep us posted.
Nov 5, 2018 at 2:16 PM
CONAGHER
MEMBER
Vacuum at Hydro vac verified, seemed to be strong. Brake pedal travels when brake line disconnected. Clutch side of master is functioning as designed.
Nov 5, 2018 at 3:18 PM
CERTIFIED EXPERT
Sounds like you have an issue with the hydro-vac unit.
Clutch side of master is functioning as designed. Can you explain this?
Nov 5, 2018 at 3:23 PM
CONAGHER
MEMBER
Hydro Vac rebuilt and new master cylinder installed both in November 2018. Slave cylinder on clutch side of master working as designed. All four Wheel cylinders rebuilt in 2010.
Nov 5, 2018 at 3:30 PM
CERTIFIED EXPERT
It sounds like you have an issue with one of the brake flex hoses. They can become clogged internally. Here is a video of how to replace the brake hoses:
I fixed this issue yesterday suspecting the same thing, a clogged line. Pedal travels freely when brake line disconnected, stiff when line is connected. Pulled line between master and Hydro-Vac and discovered flex portion of line to be clogged.
Thanks for the help!
Nov 8, 2018 at 5:06 PM
CERTIFIED EXPERT
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help.
