Sticking brakes
1998 CHEVROLET S-10
323,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
WHETO1977
  • 10 POSTS
I've replaced calipers, brake shoes, speed sensors, brake hoses, brake booster, master cylinder, rear metal brake line, both front bearings. My front brakes will stick and get hot and cause truck to shake at high speeds. Still have problem. No lights no codes.
Jul 20, 2019 at 10:38 AM
Good afternoon,
When the brakes stick, do you mean they lock up or just drag?
If you open the bleeder in the calipers, does fluid escape the wheel spins free?
Jul 20, 2019 at 10:53 AM
WHETO1977
  • 10 POSTS
They drag , I let it sit and it frees up.
Jul 20, 2019 at 12:20 PM
WHETO1977
  • 10 POSTS
I noticed when I worked on the truck to do the speed sensors the drivers caliper was harder to push in to make it fit with the brake shoes than the passenger side.
Jul 20, 2019 at 12:22 PM
You said you replaced the caliper? Why did you have to push it in? Replacements all come with the piston already retracted.
Jul 20, 2019 at 12:24 PM
WHETO1977
  • 10 POSTS
That caliper was already on the truck for awhile and when I serviced the speed sensors I had push the caliper piston In to allow the caliper and shoes to fit over the hub.
Jul 20, 2019 at 12:33 PM
If you open the bleeder valve, does the piston push back nice and easy?
Jul 20, 2019 at 12:39 PM
WHETO1977
  • 10 POSTS
I didn't do it that way. I'm going to have to remove it and try it . Would that tell me that if the fluid comes out the bleeder then the hose could be bad.
Jul 20, 2019 at 12:43 PM
That is correct or the ABS unit has dirt in it from the module to the caliper.
Jul 20, 2019 at 12:52 PM
WHETO1977
  • 10 POSTS
I took the ABS module and blew it out to see if it had trash . It didn't .
Jul 20, 2019 at 12:53 PM
Did you blow through the line from the wheel affected?
Jul 20, 2019 at 12:55 PM
WHETO1977
  • 10 POSTS
No just the unit.
Jul 20, 2019 at 12:57 PM
WHETO1977
  • 10 POSTS
I just pushed the caliper in and opened the bleeder and fluid came out but still took some force.
Jul 20, 2019 at 1:01 PM
Okay, then the caliper is no good.
https://www.2carpros.com/articles/brake-caliper-replacement
Jul 20, 2019 at 1:31 PM
WHETO1977
  • 10 POSTS
Headed to town to pick one up. They have the one that has the metal piston instead of the phanalic coated one.
Jul 20, 2019 at 1:36 PM
Sounds good. Keep me updated.
Jul 20, 2019 at 1:39 PM
WHETO1977
  • 10 POSTS
No problem, thanks.
Jul 20, 2019 at 1:50 PM
You are welcome.
Always glad to help.
Jul 20, 2019 at 1:52 PM
