Sticking accelerator
2006 CITROEN C5
80,000 MILES
EASTMAP
I have a C5 2.00 VTR, when I depress the pedal to speed up and change gears, the accelerator sticks at the revs it reached before changing gear. Is there an area or location I can check, grease etc. to stop this on the cable, or where is the cable located?
Thanks
May 11, 2013 at 5:34 AM
HMAC300
  • 48,601 POSTS
we have no info on this car but try cleaning the throttleplate on both sides with choke cleaner and iac hole. you may not have a cable to throttle it is probably electric. so it may be your gas pedal sensor.
May 11, 2013 at 5:50 AM
