Steering wheel vibration
2006 NISSAN MURANO
133,000 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
SHOW36
  • 4 POSTS
I have a 2006 Nissan Murano that needed a front wheel bearing replaced. I replaced the wheels bearing with no issues. Upon a test ride after about 20 seconds of driving not right away the front end was vibrating as well as the steering wheels. It never happened before. Even as I slowed to 5 mph I could still feel a pulsating in the steering wheel. Any help would be appretiated.
Mar 7, 2016 at 6:54 AM
WRENCHTECH
  • 20,761 POSTS
Check your wheel that it is mounted correctly and the lugs are tight. Jack the wheel and run it in the air to see if it is turning straight.
Mar 7, 2016 at 7:11 AM
SHOW36
  • 4 POSTS
Everything seems like it's running straight. The vibration almost feels like it happens after each wheel revolution.
Mar 7, 2016 at 5:56 PM
WRENCHTECH
  • 20,761 POSTS
Something went seriously wrong and you need to find it before driving it too much. You should probably have someone else look at it and put the wheel on a balancer to see if it has any issues while examining the suspension also.
Mar 7, 2016 at 6:04 PM
SHOW36
  • 4 POSTS
Actually I can't even drive it because it shakes so much. I didn't think the new bearing would do this. I put everything back tight and with no issues to. Is there a right side up or down for a complete sealed wheel bearing?
Mar 7, 2016 at 6:09 PM
WRENCHTECH
  • 20,761 POSTS
You really need someone else to look at this. You are missing something important.
Mar 7, 2016 at 6:14 PM
SHOW36
  • 4 POSTS
Ok will do thank you for getting back to me
Mar 7, 2016 at 6:22 PM
