Steering wheel shake
2012 CHEVROLET CAMARO
60,000 MILES • 6.2L • V8 • 2WD • AUTOMATIC
ALFONSO1740
  • 5 POSTS
Steering wheel shakes only when braking. Replaced both tires and balanced them. Replaced both front rotors and brake pads. Aligned the whole car as it is still shaking. Please help.
Jan 7, 2018 at 8:03 PM
Please try to rotate the tires front to rear I think you have a belt inside one of the tires that is starting to come apart.
At that miles I do not think it can be lower ball joints but you never know. Here is a guide that should help:
https://www.2carpros.com/articles/steering-wheel-shakes-when-accelerating-or-braking
Jan 9, 2018 at 1:43 PM
ALFONSO1740
  • 5 POSTS
I need the runout tolerance on hub assembly and rotor for 2012 chevy camaro 2ss
Jan 12, 2018 at 11:24 AM
What ever happen on the steering wheel shake? + or - .004
Jan 12, 2018 at 4:58 PM
ALFONSO1740
  • 5 POSTS
Shake is still there. Got some help from my mechanic friend and says if the rotors keep grooving in making the steering wheel shake then you have to go deeper then that to the hub.
Jan 12, 2018 at 5:03 PM
You should be able to jack the front of the car up and just spin the tires to hear which one is hitting. Then maybe you have sometime under rotor or you don't torque the wheel on correctly warping the hub?.
Jan 12, 2018 at 5:33 PM
