The power steering seems to work fine at higher speeds but when going really slow like parking or maneuvering around objects slowly etc. where the RPM's are low, the steering wheel has to be turned back to center manually. It won't move on its own at all. Sometimes when making a turn on the road, I have to make sure I finish the turn by accelerating a little faster than normal to make sure the steering returns to center. I've not noticed any leaking power steering fluid. The reservoir is full and there is not squeaking or squealing but I've only had the car for a few days. Any help someone can give would be appreciated. Not sure if it's low pressure in the power steering pump due to a leak in the pump or if it's the steering rack. I've no idea how to check a steering rack and I'm guessing a new steering rack would be worth more than the car. The only thing done for certification was the replacement of two front lower forward arms and joints. The car seems to stay straight when it does return to center, no noticeable wandering to the left or right.
May 11, 2019 at 7:22 AM
