The blinker switch in the column was replaced by local mechanic six months ago. a few days ago I noticed the upper shaft which is attached to steering wheel with large center nut moves out of the steering column over half an inch by its self. The lower portion of shaft protruding from bottom of column does not move up or down. Apparently the shaft inside the column is two piece, but the wheel still turns the vehicle with the shaft out of the column a bit. Do you have any suggestions as to why the upper half is not staying in the column? How to repair the issue along withe a blow-up diagram of the column- for column shift automatic transmission 700R4, non tilt, wiper switch on dash (not in column)? Thanks all!
Aug 28, 2017 at 3:20 PM
