On that truck you are lucky, it has an easy to remove return line on the side of the reservoir. You start by removing as much fluid as you can from the reservoir, then remove that line and cap the fitting on the reservoir. Put the open end into an empty container large enough to hold a couple gallons of fluid. Now fill the reservoir with the new fluid and have someone start the engine while you add fluid, have them turn the wheel full left and full right and run a couple liters through it. Shut the engine off, Remove the plug from the return fitting and put the return line back on. Then top off the fluid, start the engine and turn the steering wheel lock to lock. Shut it off and top up the fluid to the cold level. Let it set overnight or so and check the level again. Done. Two important things, keep the fluid going into the pump as close to the amount coming out and don't let it run dry. You don't want a bunch of air in the system, it can make the pump noisy until it purges out of the system.
Nov 5, 2019 at 12:02 PM
